Hey, I'm an FSAE student and was simmulating our current suspensions which are double wishbone pushrod to dampers (Both front and rear),
When I used the data provided from BAJA and SAE libraries,
I am being able to simulate the Front SLA Susp with push rod, but as I model the rear susp I am only being able to simulate using a pull rod setup.
and if i uses push rod Coordinates and then simulate it would give inaccurate results
