I would like to understand how PSIM determines the maximum allowable simulation time step for a circuit.
According to the PSIM documentation, the allowable maximum time step is calculated automatically and compared with the user-defined time step, and the smaller value is used for simulation. However, I have not found details on which circuit parameters or components are used in this calculation.
As an example, I attached a simple buck converter circuit. When I run the simulation, PSIM reports that the maximum allowable time step is 5e-9 s.
My questions are:
- Is the time step based on switching frequency, PWM signal, device models, parasitic elements, or other criteria?
- How can I identify which component or parameter in the circuit is limiting the time step to 5e-9 s?
I am using PSIM 2025 Student Edition.
Any explanation or references to the relevant documentation would be greatly appreciated.
Thank you.
