Is there an API/documentation for S-frame 2026? not S-foundation but S-frame itself?
Hi Farid,
Thanks for getting in touch. I'm afraid that S-FRAME does not have an API. With that said, many of our users will automate model creation/management, etc. via manipulating the .TEL file itself (which is an ASCII file), or by working with the integrated MDB files. I'd be curious to learn more about what you are hoping to do with the API access, and if one of the other options may work in its place?
Regards, Matthew Sauer
Hi Matthew, I was hoping to develop a live BIM link to Idea Statica. You're right, this is possible with the .TEL file itself but the issue is with linking the results since they are stored in binary files. Exporting the results to an MDB file is a workaround but it requires a manual export and I wanted to see if I could avoid that. Thank you,
Thanks for the elaboration, Farid. Not at this time, but I will raise this request with our team for future consideration.
