Hi everyone,
I am currently working on modeling a composite tennis racket to simulate the impact of the ball with the racket strings.
I have a few doubts regarding the simulation of the strings: should I represent them using 1D beam elements ? Also, what type of contact should I implement between the strings? Would an "Edge-to-Edge" contact in Radioss be the right choice?
Furthermore, regarding the grommets/holes where the strings pass through the frame, do you recommend using an RBE element?
If anyone has already worked on a similar problem, could you please help me out or share a .rad sample file so I can have a reference example?
Thank you in advance for your help!
