Description: Hello, I'm doing the Tutorial: Inductance Computation (6 Magnetostatic Non-linear case) (with my own geometry, everything else is the same as in the tutorial)
There are 3 ways described to compute the inductance.
- Linear Inductance
- Energy Inductance
- Local Inductance
For some reason my Flux crashes every time while I'm trying to create the 2D curve for Linear Inductance and also for Energy Inductance.
More Details about the crash window:
In the output window I see:
Analysis of variation computation(s) finished
EvolutiveCurve2D[Linear Inductance] created
And at the bottom left of Altair it says: New 2D curve (I/O parameter) 99% computing isovalues on 10 faces.
I would like to know what may be reasons that leads to this crash?
Thank you!
Product/Topic Name : Altair Flux 2023.1
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
