Hii everyone,
I have this confusion. I performed pretension analysis in a bolted joint. The bolt is modelled as 1D Beam element, a 18kN Pretension force is applied.
The thing is when I simulate that, the displacement and stress are 1500 mm and 1000 MPa, the components joined together by the bolt, went directly inside into each other. Shouldn't they stop each other at their surface interaction, I mean collide. I even tried using contacts between them, still they went inside each other.
It is okay or any error in the simulation. Is the pretension force too big, But in reality we apply upto 400 N-m, which may generate upto 160kN of force.
Because I need to call that pretension subcase in another subcase.
For the above situation when i called the above subcase in another subcase using STATSUB(PRETENS) the displacement i got is 5mm, which is good and realistic.
