Hii everyone,
I want perform pretension analysis on gasket for checking sealing and gasket bulging when loaded.
Since gasket is non-linear I tried Radioss. I'm new to that. I tried copying RD-HM-T:1010 tutorial. It started confusing at start and at last I made something. Plates, gasket and bolts using 4 node tetra elements and Shank part of bolt as 1D srping elemnt.
For all components I used P14 solid and SPR_PRE and SPR_BEAM for pretension as per tutorial.
For all components except gasket I used LAW_2 Plas Jhons and for Gasket I used LAw_42 Ogden.
I used type 7 contact for friction contact we use GRNODE and SURF_EXT right. I did but when i tried running I got all the penetration and Interface errors in groups. When isolated them i can only see arrow pointing in all direction. I tried searching online but no ref.
I even tried Inactive 5,6 no eff.
I del that contact and made a run, the stresses are above 500 M Pa and only at the shank region where that 1D beam contacts bolt. There's no effect on other clamped parts.
Somewhere something went wrong. please help me.
If possible pls gimme a file with the setup.
Thank you.
