Hello @GTT Adam,
I tried adding a bump stop to hard-stop the suspension travel. My suspension can travel up to 50 mm in jounce and 50 mm in
rebound. To simulate the same scenario, I set the jounce travel to 60 mm and checked whether the suspension stops at 50 mm. As a result, the suspension exceeded 50 mm, and the shock began to tilt backward to compensate for 60 mm of travel. I have attached the video file
