Description: Hello, I have been trying to modernize a model that used lists to organize an assembly into the more modern Subsystem entity.
Dragging and dropping the entities in the drop down menu works fine,
However, this list has a million elements that need to be moved. I tried saving selection from that box using ctrl+w, but it only saves 1082391 elements. So my question is, where did the 3000 missing elements go, and is there an easier way to move things from this list into a subsystem?
Thanks,
Product/Topic Name : Hypermesh 2025.1 with OptiStruct
