I’m encountering an issue while trying to create the symmetry of my half fuselage. The model was built using a reference coordinate system. I then define a symmetry plane by selecting points on the open face of the fuselage.
However, when I mirror the fuselage, the two surfaces do not merge properly and there is a small gap between the two half fuselages.
Is there a way to automatically merge the two fuselages, other than manually merging each point one by one?
Thank you.
