Dear Altair Support Team,
I hope this email finds you well.
We are currently using the bingham type within the VISCOSITY_MODEL command in AcuSolve to simulate a non-Newtonian fluid and have some questions regarding its parameterization.
Upon reviewing the model's governing equation in the AcuSolve documentation, we understand that it is a generalized model incorporating several physical effects, which differs from the conventional Herschel-Bulkley-Papanastasiou (HBP) model we are accustomed to. Specifically, we are uncertain about the best practice for determining the following three parameters from our experimental rheological data:
bingham_viscosity (μ₀)bingham_time_constant (η)bingham_infinite_shear_viscosity (μ∞)
Our attempts to calibrate these parameters using our rheology data have led to simulation results that deviate significantly from those reported in our reference literature.
To resolve this discrepancy, we would be very grateful if you could provide some clarification on the following:
- What is the theoretical source or reference literature for this generalized Bingham model as implemented in AcuSolve?
- Has this model been officially validated against any benchmark cases? If so, would it be possible to access the corresponding validation reports or examples for our reference?
A precise understanding and correct implementation of these parameters are critical to the success of our research.
Thank you for your time and assistance. We look forward to your guidance.
Best regards,
Yu Yin
