I am using a twisted pair wire with the following values:
Metric | Value |
Core Radius | 0.000335 |
Insulation Layer Thickness | 0.0009 |
Twisted Pair Radius | 0.0025 |
Twisted Pair Length | 0.003 |
This shows no errors, but when I try to run Feko Solver I get:
ERROR 53993: Twisted pair: expecting a twist pitch length that would result in loosely wounded wires
See also message in the output file Parallel Cable Model 2.out
No greater value for Twisted Pair Length appears to remedy this until I start reaching values of around 0.1, upon which I get spammed with the error below with varying MYID codes from 1 to 12:
ERROR 39438: Geometry intersects with a cable cross section
If I input a value such as 0.002 I get the following error:
Expecting a twist pitch length that would result in loosely wounded wires. It must be greater than 0.00271988.
What exactly am I doing wrong?
