I have tried the following steps, but encountered issues. Here are my steps:
① In the first load step, I used Non-linear static analysis for bolt preload and successfully computed the results.
② Then, I added a subsequent analysis step using a generic analysis step, referenced the corresponding card in CMSMETH, and used statsub(PRELOAD) to reference the preload analysis step. The preload calculation worked normally, but a prompt indicated that Param,IR4NLCOM needed to be enabled.
③ However, when running the second analysis step, an error occurred: "Specified load case number 1 out of allowed range (1-0)".
My goal is to obtain the stiffness changes after preload, consolidate them, and generate a superelement.
