I was wondering how the fatigue constraint, which can be set in the DTPL card for a topology optimization, influences the topology optimization result. In the out. file, I can tell that no sensitivities are calculated for the fatigue constraint, only a check is included. However, the final result with/without fatigue constraint shows a difference in the element distribution.
Therefore I wonder: How does the fatigue constraint constribute to the change of the design variable? Does somebody know?
This is a more general question, therefore I did not attach any model files.
Thank you in advance,
Jenny
