Hello, since last week I have a new computer, I work with SketchUp 2026 and Thea Render v2026. If I have the active renderer window open (SketchUp and Thea), I see changes such as higlights, shadows and others. If I start changing the lighting intensity in the Light settings tab, no change is visible in the render. It's the same with objects: if I add or remove an object in SketchUp, I don't see the change in the active render window. I have to turn Thea off and on again for the change to load. I don't know what to check anymore, I spent several hours on it yesterday without success. Thank you for any help.
