I am encountering an issue during volume mesh generation in Altair SimLab while working on a CFD model of a jet mill (including a high-speed rotating classifier wheel). I would like to seek your professional advice on the recommended workflow for this scenario.
[Model Setup]
- Topology: The model consists of two fluid bodies:
Body 1 (Stationary domain) and Body 2 (Rotating MRF domain). An Imprint operation has been performed to ensure a conformal fluid-fluid interface. - Surface Mesh: The surface mesh generates successfully. Mesh sizes: 3 mm global, 1 mm at the conformal interface, and 0.3 mm on the classifier blades.
[The Problem]When generating the Volume Mesh with Boundary Layers (BL) enabled, the mesher fails with the following error:Error:: Body 1 has overlap edges
