I'm trying to do a model of an 9 mm bullet impacting a laminate on RADIOSS.
I'm only using the lead core of the bullet with the LAW49 STEINBERG (Hyd_JHOOK and jonhson cook are also modeled). The laminate has got the law12 and is only a 3D block right now.
Therefore, i tried using Finite Element only, then SOL2SPH and finally SPH for modeling the bullet. The SPH model and a tetrahedric mesh model seems to work for the shape of the bullet but i would like to keep most of the solid with SOL2SPH or only with Finite Element. (There is also a rebond of the bullet that i don't want, is it because of this enormous simplification for the plate ?).
The issue is that i don't find a way to end the simulation, without having strains errors/ negative volume and distorsion of elements. I would like to keep a model with hexa element instead of tetra to also be more accurate.
Have you got any ideas of criterias or options i should use based on my model ? I would gladly have your help.
In the mean time, if i want to model the brass jacket of the bullet using sph modelisation, how can i deal with the interaction between both particules of the lead core and the jacket ?
Thank you for your help in advance !
