Is it possible to plot:
Short Circuit Current / Open Circuit Voltage against the Field Current in Altair Flux/FluxMotor ?
I recommend you have a look at the FluxMotor Wound field motor tests. Make sure to select the slider to Generator mode on the top left and you will find an open circuit and short circuit tests which can help you characterize this type of machine as you are expecting.
Best regards
