I have noticed that every time I want to run a sine wave I-Ψ-N simulation in Accurate computation mode, I get the following error:
The test Working point, Sine wave, Generator, Current-Control angle-Speed failed due to the following problem:
Cause : Failed to execute the flux bloc with name BlockSmPm3WPCurrentSpeedPsiTransientFluxComputation #100.18.10
Type : Internal error
I only seems to happen with motor topologies that have no (anti) periodicity, for example: 9 slots, 10 poles:
Whenever I have a similar sized motor, but with periodicity the simulation runs fine, for example 12 slot 10 poles:
Is this a common issue? And does anybody know a way to fix this?
