Dear reader,
I am modelling a planar inductor in Altair Flux 3D. The planar inductor is evaluated at a frequency of 10MHz and the geometry is variable to obtain a specific inductance with minimal AC-resistance and area. To simulate the inductor, the volume is configured as a solid conductor region and an electrical circuit is made with a current source of 1A and the two terminals of the solid conductor. The face where the current flows into the coil is and a face where the current leaves the coil are assigned:
Meshed Geometry
It is not clear from the image, but the height of the trace is 36um, a meshed is the Z-axis with 10 imposed points in this 36um). Other dimensions are roughly: inner diameter 5mm, trace width 6mm, spacing between traces 0.6mm.
My first question is: why can the predefined inductance sensor only be used on a stranded coil conductor, not a solid coil conductor?
Now I have been calculating the inductance with an integral over the complete domain and multiplying B*H. This magnetic field integral could be used for determining the inductance but the result is way off when comparing to the modified wheeler equation (function used to estimate the inductance of a square planar inductor). How would you suggest to determine the inductance and AC-resistance from the simulation result?
Current density in coil
Hopefully you can give me some directions.
Best regards,
Bart
