What are the main use cases and advantages of using OpenVSP before setting up a simulation in FlightStream ?
Hi Hugo Long,
The main advantage is that if you convert your OpenVSP model as P3D format, the mesh can directly be used within Flightstream.
Also, see video below on how we can convert P3D into CCS format:
https://www.youtube.com/watch?v=0BE6jnAoh-w
Share your models, scripts, workspaces, and more with the Altair Community.
