What is the recommended approach for meshing complex non-lifting geometries such as a rotor hub? Is the TFI mesher appropriate for this type of geometry? Or an external software ?
Thanks !
Hi Hugo Long,
It'll depend on how complicated your rotor hub is. If it's a simple hub, you can also use the CCS approach. TFI meshing is also appropriate for this kind of geometry.
Email me (shahfiq.shahjahan@siemens.com) and we can perhaps set a quick call to go through this.
Share your models, scripts, workspaces, and more with the Altair Community.
