Here, in port 2( near the t shape slot at the bottom) I am getting about 0dB reflection, Can you kindly check this model and fix the excitation of feed 2?
Hello @sswh2,
I checked your model with 2024 version and found out the followings.
Best regards,
Jaehoon
Hi @sswh2 ,
I agree with @Jaehoon and would also use a simplified radiator; see the attached model. Note: The wires are probably too thick. If they really need to be that thick, I would recommend cylinders.
Best regards, Torben
You can easily delete the voltage source added to the port 2,
and add a load (of any impedance, under source/load tab) to the port 2.
Please do not delete the wireport2…
Sir, thanks for making sure the connections are correct in this feeding.
Thanks sir, @Torben Voigt .
@Torben Voigt sir and @Jaehoon sir
Instead of having two ports, if I want to place a resistive load at the port 2 location, then can you kindly send me the model on how to do that in FEKO with my design?
Thank you!
