I cannot use PSIM student license now. I have tried entering my account information at license setup - altairone login, and altair license utility - managed licensing - authorization, both in account information and auth code. None of these works.
@Xingyu_Chen
Please refer to the following guide (Step 3 and 4) for detailed instructions on installing and activating your Altair Student Edition software using your Student Edition license key -
Please take screenshot of error(s) and share if the issue persists
Thanks
Hello Ankita,
I followed the instruction. This is what I got now.
@Xingyu_Chen Your license key has been deactivated in Altair One, and you can now reactivate your student license using the same key.
Kindly note, The Altair Free Student Edition license is valid for use on only one device, it cannot be shared or activated on multiple machines at the same time AND Deactivation and reactivation feature is only if a computer breaks down or reformatted and is only allowed a few times per user preprogrammed into the system.
You can deactivate the license from one machine and reactivate in another by yourself if you have access to both machines as per – https://community.altair.com/discussion/34280/altair-student-edition-deactivate-from-one-computer-to-activate-in-another-in-the-rare-case-a-computer-is-lost-or-malfunctional#latest
Thank you. The license works now. But I run into a new issue. After the simulation is done, the software is stuck at the waveform window and gives no result. Would you please help with this? Thank you!
