Dear Support,
I am currently producing the results in spherical format. Is it possible to generate the output in azimuth-elevation (az-el) format as well?
In current workflow the elevation and azimuth angles are always reported as positive values in the some range. I would like to know is it possible to obtain outputs where azimuth or elevation can take negative values and if there is a setting or potion in FEKO that enables such a representation.
Thank you very much for your assistance.
Best Regards
