I have a new install of Inspire that I am following tutorials to get familiar with the UI. I ran an optimization this morning that produced some results but were different from the tutorial videos results. I ended up remodelling a part of the structure as it was extruded in the wrong direction and when I ran the next optimization it will begin to run, the status bar doesn't show 100% but clicking show run displays that it has completed and a time that it finished at. Reading the .out file I have bad termination of one of your application processes and shows exit status (c0000138) each new run that I attempt. Other files show that meshing was completed successfully for all 4 parts. The solver launches 4 parallel process which all immediately crash with exit status (c0000138) the run history path is set to C:\Users\Noah\Documents\Altair\extensions but the run folders auto generated by Inspire contain special characters like % and brackets ( ). This is a brand new install of 2026 which is installed in C:\Program Files\Altair\2026 and I don't see any updates that are available to try. Is the model file corrupted somehow?
I am running Windows 10 with
- CPU: 4 core 8 logical processors
How can I fix this issue as I need to learn the basics for a course project with much more detailed geometry that will likely take hours to compute an optimization? I have attached the model and some relevant files.
Thanks
