In my current simulation, I need to establish contact between two components. Initially, the contact occurs at a single point(small area), but as the load increases, it transitions into surface contact. However, during the simulation, the initial point contact leads to excessive localized plastic strain at a single node, causing convergence issues.
Could anyone suggest the best approach to obtain accurate material curve results while avoiding or minimizing these unrealistic plastic strains in the assembly?
