hello,
I want to ask
Is it possible to resume uncomplete analysis with optistruct?
Because electricity in my house goes out and my pc shut down.
The analysis have been running for 2 days.
Is it possible to resume it without getting any error?
A nonlinear analysis can be restarted or continued from the last point at which the previous analysis was interrupted.When running an analysis, you can write the model information and analysis state information which can be used for restart.
http://insider.altairhyperworks.com/wp-content/uploads/2017/01/T-amp-T-1219-OptiStruct-Restart-of-Nonlinear-Analysis.pdf
Just complementing the answer.
You need to request the restart upfront to have this ability.
Otherwise you will need to run ot again.
Run your model with RESTARTW and if needed, restart again
