200mm直径的离心风扇跌落仿真,使用四面体网格建模,四面体单元属性应该如何设置更准确
Hi I hope it is fine for you I am replying in English.
If you are using tetrahedral element, the property setting depend first on the type of tetra elements you are using:
Regarding other formulation setting such as Ismstr parameter, I suggest to use first automatic settings (Ismstr = -1, Icpre = -1)
