I read on a post that if i had this problem i should ask on the community to do that, because i don't have acess on my old notebook.
Hi @BrunoZufelato
Your license key has been deactivated in Altair One, and you can now reactivate your student license using the same key.
Kindly note, The Altair Free Student Edition license is valid for use on only one device, it cannot be shared or activated on multiple machines at the same time AND Deactivation and reactivation feature is only if a computer breaks down or reformatted and is only allowed a few times per user preprogrammed into the system.
You can deactivate the license from one machine and reactivate in another by yourself if you have access to both machines as per – https://community.altair.com/discussion/34280/altair-student-edition-deactivate-from-one-computer-to-activate-in-another-in-the-rare-case-a-computer-is-lost-or-malfunctional#latest
Thanks
