Is there something I can do to make Inspire Cast use the same Repair engine as Inspire?
Hi @dhalpin ,
Your Inspire might have different CAD import configuration. Change the import preferences of Inspire Cast similar to Inspire and see if that fix.
Milan Raval
Thanks, Milan - yes, my STEP value is Spatial in Inspire, so I changed Inspire Cast to match. Hopefully that will improve things. Thank you!
Join us for a community conversation on Pulse Width Modulation (PWM), a fundamental technique in electric motor control, and explore how different PWM strategies can yield significantly different results. This webinar provides a comparative analysis of various PWM methods and their effects on motor efficiency, torque…
Join us for a community conversation to discover the Advanced Iterative Solver(AIS) in Simcenter Feko and its application to electrically large and computationally demanding electromagnetic models. The session will provide a general overview of how iterative solution methods can help improve efficiency of large scale…
