L4UGJ-AKZH3-PQ356-TBYO3 This is my old license And this is my new computer I´ve seen that you can help reactivating or at least deactivating but cannot coment those conversations could you please help its for class.
Windows IP Configuration
Host Name . . . . . . . . . . . . : MI-W1YH9524 Primary Dns Suffix . . . . . . . : am.hexagonmetrology.com Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : hexagonmetrology.com am.hexagonmetrology.com cn.hexagonmetrology.com eu.hexagonmetrology.com roa.hexagonmetrology.com lgs-net.com hexagon.com volumegraphics.com forming.com ad.dptechnology.com mscsoftware.com
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Ethernet Connection (22) I219-LM Physical Address. . . . . . . . . : 4C-D7-17-EC-34-7C DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2806:103e:2f:4c28:754a:3156:cd9c:a982(Preferred) Temporary IPv6 Address. . . . . . : 2806:103e:2f:4c28:152b:81f4:1bdf:3e16(Preferred) Link-local IPv6 Address . . . . . : fe80::af73:9d80:5156:8815%9(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.78(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Thursday, February 26, 2026 1:44:05 PM Lease Expires . . . . . . . . . . : Friday, February 27, 2026 1:44:05 PM Default Gateway . . . . . . . . . : fe80::da21:daff:fe19:2f20%9 192.168.1.254 DHCP Server . . . . . . . . . . . : 192.168.1.254 DHCPv6 IAID . . . . . . . . . . . : 105699095 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-30-4A-76-A2-4C-D7-17-EC-34-7C DNS Servers . . . . . . . . . . . : 192.168.1.254 fe80::da21:daff:fe19:2f20%9 NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wi-Fi:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Wi-Fi 6E AX211 160MHz Physical Address. . . . . . . . . : C8-15-4E-41-8F-52 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 1:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter Physical Address. . . . . . . . . : C8-15-4E-41-8F-53 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2 Physical Address. . . . . . . . . : CA-15-4E-41-8F-52 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet 3:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Fortinet Virtual Ethernet Adapter (NDIS 6.30) Physical Address. . . . . . . . . : 00-09-0F-FE-00-01 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : C8-15-4E-41-8F-56 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
@Rahul_P1 Sorry for reaching you directly i´ve seen you usually help :) Pleaseeee
Hi @Sanarpana
Your license key has been deactivated in Altair One, and you can now reactivate your student license using the same key.
Kindly note, The Altair Free Student Edition license is valid for use on only one device, it cannot be shared or activated on multiple machines at the same time AND Deactivation and reactivation feature is only if a computer breaks down or reformatted and is only allowed a few times per user preprogrammed into the system.
You can deactivate the license from one machine and reactivate in another by yourself if you have access to both machines as per – https://community.altair.com/discussion/34280/altair-student-edition-deactivate-from-one-computer-to-activate-in-another-in-the-rare-case-a-computer-is-lost-or-malfunctional#latest
Thanks
