How can we control the break angle for 2D surface mesh selection in Create Groove Weld?
While creating a groove weld between two parts, the root edge and toe side 1 are selected correctly. However, when selecting toe side 2, the tool also picks faces outside the groove.
Is there a way to limit the selection using break angle or another setting to restrict it only to the groove faces?
