RE: Altair slc thermal deformation and stress of rubber material under temperature extremes
Too long to post on list, see github
https://github.com/rogerjdeangelis/utl-altair-slc-thermal-deformation-and-stress-of-rubber-material-under-temperature-extremes
Original Post
https://community.altair.com/discussion/64949
THERMAL STRESS ANALYSIS FOR RUBBER MATERIAL (fixed edges as in post)
Stress State: Tensile
Stress Magnitude: 0.01 MPa (10 kPa or 1 psi)
Risk Level: Low
Deformation Potential (if unconstrained): -10.00 mm per meter length
Physical Interpretation: MATERIAL ATTEMPTS TO CONTRACT BUT IS CONSTRAINED, INDUCING TENSILE STRESS
SUMMARY
Aspect Value
Stress State Tensile
Stress Magnitude 0.01 MPa (10 kPa or 1 psi)
Risk Level Low
Deformation Potential (if unconstrained) 10.00 mm per meter length
Physical Interpretation Material attempts to contract
but is constrained, inducing
tensile stress
