I recently downloaded hypermesh and optistruct. However I can´t really use de program. For example, I cannot create a material and add properties to it, the following image is the only thing I see. I cannot create for example beams or when I try a fatal error occurs. In addition I cannot add any other properties. Basically, I can create anything to perform a analysis. I already tried uninstalling and downloading again.
Best regards,
Thank you
