https://help.altair.com/hwsolvers/os/topics/solvers/os/mathe_bulk_r.htm
How's I and J calculated?
Thanks
Qin
Based on the generalized polynomial form (Mooney model) shown in your image, here is how I and J are calculated or defined:
The terms Iˉ1Iˉ1 and Iˉ2Iˉ2 in the equation refer to the deviatoric (distortional) strain invariants.
In continuum mechanics, the strain invariants are derived from the right Cauchy-Green deformation tensor C.
The term JJ (referred to as JdasJdas in your text, likely a typo or specific variable name for "Jacobian Determinant" or volume ratio) represents the volume ratio.
As noted in your image description:
It mangled my post.
HTH
Thanks, I will reference it in the publication.
