Hii,
I want to perform a heat source at constant temperature moving on a body, I need to determine the effect of heat on the body,
There is a tutorial in radios but it ain't in detail,
Suggest me some methods, if its possible in optistruct that would be great
The heat source moving at the defined and the heat transfer between the source and body, deformation and stress are need to be determined
