Hi, I tried to load the surface mesh from CFD which is in PLOT3D format. And I ran the case M=0.84, AoA = 3.06 deg with the transonic field panel method. I just ran the case without boundary-layer coupling. The pressure contour does show the Lambda-type shockwave. The surface grid is attached. Not sure whether you can repeat this case and compare the results.
