I have a board now, and I need to move it up 50mm in the first working condition. In the second working condition, I need to move it up 20mm on the basis of working condition one. In the first load step, I used SPCD to move it up 50mm, and in the second load step, I used forced displacement to move 20mm and continuous load step. However, the result is that the first working condition moved up 50mm smoothly, but the second working condition did not move 20mm relative to the first working condition, but moved 20mm relative to the initial state. What should I do to achieve the desired result?The board below is just my reference
