I currently have two parts with an interference fit of 0.55mm. When modeling the actual model, it was through penetration, and the mesh division was also through penetration. I set Clearance=-0.55 in the optistruct contact, but the mesh nodes remained through. Is this correct? Or do we need to manually move the grid nodes to not penetrate, and then set Clearance=-0.55? Which of these two modeling approaches is correct?
