Hello, I’m having a small issue with composite optimization. I need different thickness constraints on my part during FreeSize and Size optimization. The HyperMesh help site mentions that it’s possible to assign multiple LAMTHK constraints to one DSIZE card, but I can’t figure out how to do it since there is only one field for LAMTHK in the DSIZE card. Do you know if this is possible? If not, is there another way to limit the thickness in different areas of the part?
I’m working on a wing-shaped structure made from a “solid” (massive) carbon laminate, where the curvature should come from ply drops.
By the way, I’m using v2025.1
Any tips or guidance would be really appreciated. Thanks a lot in advance!
