Hi, I am implementing a temperature-dependent shell material in Radioss UMAT via dll.
sigpc29c
TEMP(NEL)
TEMP(i)
UVAR
/MAT/USER/29
Thanks!
Thank you. i was using 2021.2 version of radioss, but in 2026 version its worked completely. Thank you.
Hello Dhaval.
I'm attaching an example of a temperature-dependent Young Modulus Subroutine.
I hope it helps.
Thank you for your example.
I checked the nodal temperature, and it is showing as zero. I also tried modifying some parameters, but the value still remains zero. I wanted to ask if there is any specific reason for this behavior, or if there is something else that needs to be defined or activated.
I would appreciate your guidance on this.
regards, Dhaval Kukadiya
Hello
Which version are you using? I cannot reproduce the issue in v2026.
