My problem is that the Read Excel and Read CSV operators are not working well. It is possible to load files into them and run them but it is not possible to select the attributes.
PS When I use a a proces (.rmp) from a fellow student which uses a read Excel then it is possible to select attributes but when I load a file of my own in that operator Read Excel that is not possible. Same goes for using the tutorial examples. (I see there the attributes and I can change them but I am unable to change the file in that specific Read Excel operator.
PS I already Uninstalled RM and Installed it again but that did not fixed the problem !!
Kind regards,
Leen
