I am modelling a permanent magnetic coupling. Unfortunately for IP reasons I cannot share the analysis file. The outer coupling has a motion as defined below, with the max time as one cog in the coupling. When I try to run the model, I receive the attached error log stating there is not a value in the Ang Pos of the motion. I am unsure what to do to correct this - any recommendations would be greatly appreciated thank you.
