Hello, Fluent is coupled with Edem. Can I only use the aggregation function of Edem to handle the thermal properties of particles within the DPM framework of Fluent?
In a coupled simulation each particle is considered an individual element in the fluid. So if you have something like a meta-particle, which is made up of multiple individual particles, the CFD code only sees the individual particles.
Regards
Stephen
