I have a question related to topology optimization in Flux 2024.
I would like to launch the optmization manually, by writing a .py script and running it in the Python editor zone of Flux. I need to run it manually because I would like to use an input .fem file that is not automatically generated, rather written by me (the automatic .fem file doesn't contain some additional set up specifications for the optimization in Optistruc that I need).
Is it possibile? And if yes how/which expression should I put in my .py file?
If no, is these anything similar I can do to add some set up parameters present in the optimization in Optistruct that are not available in the parameters that can be changed in Flux?
Thank you in advance
