I would like to know the differences between "Equivalent Strain", "Major Principal Strain" and "Minor Principal Strain". Thanks!
Thank you for the excellent response!
Ken
Hello
In SimSolid, Major and Minor Principal Strains are the maximum and minimum normal strains at a point, occurring along directions where shear strain is zero; the major principal strain represents the largest tensile (stretching) strain, while the minor principal strain represents the largest compressive (squeezing) strain. Equivalent strain is a single scalar value that combines all strain components into one measure of overall deformation intensity, independent of direction, similar to von Mises stress. Principal strains are mainly used to assess tension- or compression-driven failure (especially for brittle materials and buckling), whereas equivalent strain is commonly used for evaluating ductile material behavior and plastic deformation.
In simple leymans term, major principal strain tells you where the material is being stretched the most, minor principal strain tells you where it is being squeezed the most, and equivalent strain gives you one overall number that says how much the material is deforming in total, without worrying about direction.
Thanks
Sourav
