In Simlab, welding seams support solid welding seam modeling and node fusion using connection functions. However, in Hyperlife (Basic Version), welding seam fatigue only supports the Volvo method and does not support solid welding seam fatigue. It seems that Hyperlife (Welding Evaluation Version) supports static and fatigue strength of welding seams. So, does it support the hot spot stress method for solid welding seams? If it is not supported, simply using Simlab for weld seam modeling will inevitably result in concentrated stress at the weld seam, so it cannot be verified without following the specifications; But I understand that Dassault's fe safe defines weld toes manually through unit sets and node sets, so I am curious if Hyperlife (welding evaluation version) can evaluate solid welds? Do you have any case studies to share?
