I really need some help knowing if the multiscale designer is capable of steel fibers in UHPC. Can bond-slip, pull out behavior be modeled in MDS??
I am attempting to model UHPC using Altair Multiscale Designer (MDS) with discontinuous short steel fibers. Since the tensile behavior of UHPC is strongly governed by fiber–matrix interfacial mechanisms such as bond–slip, debonding, and fiber pull-out, I would like to ask whether MDS provides any way to explicitly or implicitly represent these interface effects. In particular, can bond–slip or pull-out behavior be modeled through any built-in material laws, equivalent interface formulations, or recommended calibration strategies, or are discontinuous fibers in MDS always treated as perfectly bonded continuum inclusions that share load from the elastic stage? Clarification on whether fiber–matrix interfacial behavior can be physically represented within the current MDS framework, or whether this should be considered a fundamental modeling limitation, would be greatly appreciated. If it is impossible, then isn't creating uhpc in mds not appropriate?
Also I could use some help in selecting the nonlinear law for UHPC concrete matrix
