Hello, I have a circuit diagram of simple buck converter in PSIM v.2025 extention .psimsch into the Twin activate 2025.1. I take the inductor current at the input side and use the "in Link node" and at the output terminal of inductor i used the "out link node" and also used the "out link node" at the output voltage. i want to chek the impact of inducor current inside the circuit.
I already make a same circuit and run it for a 1 sec and save the data points of "inductor_in" at the input side pf inductor and "inductor_ou" at the output side of the inductor and the points.
for information:
buck.psimsch: used for collect the time depended signal
buck2.psimsch: used for comsimulation with Twin activate
csv file in which i save the time depended signal
